gspearson
Expert
Message 1 of 9
Not Complaining - just intrigued
Having had a boost engineer here back in September, who gave me a 75M download speed for a week, I'm now following the vagaries of speed. After the 75, the speed fell back to a very consistent 65  for two months. Then this week it moved to 69.9 and has stayed for 5 days.  The download noise figure has moved from 6.1 to 4.6. No complaints - but how is the data rate shown by the Hub now higher than the Max data rate?  I'm on Infinity 2, 50 metres as the crow flies from the box.
8 REPLIES 8
licquorice
Message 2 of 9
Re: Not Complaining - just intrigued
The max rate is the speed at which you would sync at now if you re-synced, it is lower than your actual because the noise has increased. At the tim eyou synced at 74M the noise would have been lower. The hub always attempts to sync with a noise margin of 6dB.
imjolly
Message 3 of 9
Your phone line is obviously longer than 50m otherwise you would get 80mb easy - must have a detour somewhere
gspearson
Expert
Message 4 of 9
It does, it goes round the back of the houses so is probably 120m - it is a tease to see the cabinet across the road.  The boost engineer said the dreaded word aluminium.
gspearson
Expert
Message 5 of 9
@licquorice thank you. The hub rebooted itself out of the usual 15 day cycle.  I find the noise figure confusing - in the days when I was a licensed radio amateur, high signal to noise ratio was important but this noise figure reduces when things get better.  I think you are telling me that if if I reboot the hub, the connection speed might revert to the excellent 65 from the present brilliant 69.9.
Geoff
licquorice
Message 6 of 9
Indeed. The figure isn't signal to noise ratio, its signal to noise ratio margin.
gspearson
Expert
Message 7 of 9
The current programme of increasing speed for Infinity 1 talks of reducing the margin to 3dB - this is not what is going on here then, as I'm on I2?  It is just  one of those things.
imjolly
Message 8 of 9
The reduction of noise margin is still being trialled but applies to infinity 1 & 2
gspearson
Expert
Message 9 of 9
I'll just have to wait until it reboots again. I'm not tempting fate by forcing the issue.
