Distinguished Guru
Message 11 of 24
Re: Not checking for faults before migrating over
The MAC process was still in use on Jun 14th so I'm a bit surprised BT didn't tell you to get a MAC code from Sky. They didn't have to use the MAC process but that was the best way to avoid any issues. Saying that it may not have avoided a capacity issue anyway. I guess you'll never know.
You ordering around the time of the process change probably didn't help. Not your fault of course.
Message 12 of 24
Yes not my fault - you put your faith into these companies, I asked all the right questions beforehand. This is the first I've heard of all this. Not acceptable is it?
Message 13 of 24
if a MAC was not used the move of provider would have been a cease and reprovide this would have caused the delay in the new service up to 14 days and could also explain the capacity issue
Message 14 of 24
It seems that our phoneline has been working for a few days now, but not the broadband (Due to the capacity problems).
So my original reason for the post - 'Should faults be checked before migrating over?' still stands really as I feel this MAC couldn't be just the cause of all this. Especiallly listening to the Openreach Engineer's comments yesterday 'This box (pointing at the excahnge) is a load of rubbish, people have been waiting for 6 weeks for broadband and BT know about it.
This MAC subject seems to be just a side issue to me.
Anyway I'll find my way back up from the bottom of the garden now (The only place I can get a slight 3G signal) and back to the dark ages.
Message 15 of 24
Just to continue this post, I still have no broadband. Getting to 2 weeks now.
I'll have to now look for a new job as I'm now unable to do my work. But that's ok because I can claim £18 compensation for all this life affecting trouble.
Message 16 of 24
Residential lines should not be used for business use as it is a breach of the terms and conditions if you need the line for business use then you should consider as business line as it has a better SLA
Message 17 of 24
There is a great difference between the green street cabinet and the exchange a cabinet has no effect on if you can get broadband or not the street cabinet is purely a cable connection point the exchange is a brick built building which contains both the phone and broadband equipment the only exception would be for fibre service which does have a brand new cabinet built close to the old street cabinet
Message 18 of 24
It's not used to run a business - I'm sure most people have to do work at home as overtime now and again.
This response isn't an excuse for being treated this way and not relevant.
Message 19 of 24
Thanks for this information - however little it's helped me getting my issues resolved.
I do now know the difference between a cabinet and a brick building now though.
Message 20 of 24
Your comment here "Especially listening to the Openreach Engineer's comments yesterday 'This box (pointing at the exchange) is a load of rubbish," This was the reason for the explanation of the differences
