peterh42
Message 1 of 10
Not getting Infinity
Hi
I just moved into a flat and found that I am only able to get 5Mb download.  I have checked the post code and it says I can't get Infinity.
Across the road, they are getting Infinity but I can't see the cabinet they are connected to (A big green one with Infinity Is Here on it normally).  There seems to be 2 old style cabinets near by.
So how are they getting it and not me?
Post Code CM7 3RQ
Regards
Peter
9 REPLIES 9
legitimise_sailing
Distinguished Expert
Message 2 of 10
Re: Not getting Infinity
You're not connected to a cabinet. You have an exchange-only line.
To say thanks for a helpful answer, please click the white star
peterh42
Message 3 of 10
So how can I be moved off an exchange-only line as I am on a speed that I was on in around 2004?
I moved from having near 50Mb at one end of town to 5Mb at the other end and this is nearer the exchange
legitimise_sailing
Message 4 of 10
The current thinking is to install a cabinet outside the exchange and connect EO lines to that.
gg30340
Message 5 of 10
If you are on an Exchange Only (EO) line you can not be changed to another cabinet. At the moment you will not be able to get Infinity. Sometime in the future, who knows when, Openreach may install a cabinet out side your exchange and this will allow EO line to then get Infinity. At the moment all you can do is wait and see.
peterh42
Message 6 of 10
Must remember to check what the broadband is like before I move as now have until next March until I can move if I wanted to.
Well at least I am saving money Smiley Frustrated
peterh42
Message 7 of 10
So okay I am on an Exchange Only line.
Why am I only getting 2Mb when I am only straight line distance of 775 metres?
Surely ADSL should be giving me about 8Mb according to
http://www.broadbandspeedchecker.co.uk/guides/adsl_and_distance.aspx
Perhaps I am on a wet bit of string instead of copper Smiley Mad
legitimise_sailing
Message 8 of 10
You need to get your Router stats and ask in the appropriate forum https://community.bt.com/t5/ADSL-Copper-Broadband-Speed/bd-p/BBinHome
peterh42
Message 9 of 10
cheers
how do I get my router stats?
legitimise_sailing
Message 10 of 10
That depends on the router. For a HH5, it's in Troubleshooting, Helpdesk on the web interface. But you should ask in the forum I linked to.
