Message 41 of 55
Re: Not getting the 60/20 as promised
@Number86 i think it takes time to adjust sync speeds, plus now that you have 0.03 upload it could be due to that wire you use so it's worth getting a shorter & better wire.
in my experience from the up to 8meg adsl days, when i tested a really long 50m adsl cable in an effort to move my modem, my speeds dropped from 6.5meg to 1meg.
it really does depend on the wiring of equipment too, i believe the wire must have take some damage as it might be stapled badly plus the engineer did mention that the length can effect speeds...
any ways i hope shortening the wire & moving the master socket next to the modem should help... guess i will have to wait & see
Message 42 of 55
Actually, I just fixed my problem. I think the ethernet cable wasn't connected correctly. unplugged and plugged back in on the PC end, and without even a restart of anything it's pretty much fixed.
50m cable is also a lot more substantial than 20m, and I'm assuming you're not using 20+ metres? Of course cable length effects the noise/inteference which can degrade the signal. But I'd be pretty shocked if it was cable length alone causing this issue. *
*Unless it's 50m and/or damaged.
Message 43 of 55
true, i think the wire right now is about 10m long, it's most likely damaged, just realized that the plastic coating on the cable is slipping off :S
Message 44 of 55
well mine has gone down another 10meg today im getting 20/11 not worth me been on this at the minute,how long into contract do you have to cancel i.e do you have 7 days from install
Message 45 of 55
There's no cancellation period.
Have you raised a fault? What was your initial estimation?
Message 46 of 55
you can only cancel up to the activation day after that cancellation is chargeable
Message 47 of 55
hi sorry for late reply ok guess im stuck then,well it was 59/20 my estimate and for hte first 2 days i was on over 60/20 but its dropped of a lot now,do i phone bt to raise the fault and thanks for the help and advice
Message 48 of 55
Yeah call the helpdesk
Message 49 of 55
well i got a message back from David M
saying
I’ve run a few tests and the results indicate that there is a problems on the network side so I’ve raised a fault,
so will give it a few more days and see how it goes
Message 50 of 55
My download estimate was 50. I only got 30. A BT broadband engineer came out and confirmed this. He then checked with some BT technical people who said that the line would only support 34 max. What I would like to know is why aren't the marketing people not getting their estimates from their own people who clearly have a better idea of what's actually achievable.
