Actually, I just fixed my problem. I think the ethernet cable wasn't connected correctly. unplugged and plugged back in on the PC end, and without even a restart of anything it's pretty much fixed.
50m cable is also a lot more substantial than 20m, and I'm assuming you're not using 20+ metres? Of course cable length effects the noise/inteference which can degrade the signal. But I'd be pretty shocked if it was cable length alone causing this issue. *
*Unless it's 50m and/or damaged.
true, i think the wire right now is about 10m long, it's most likely damaged, just realized that the plastic coating on the cable is slipping off :S
well mine has gone down another 10meg today im getting 20/11 not worth me been on this at the minute,how long into contract do you have to cancel i.e do you have 7 days from install
hi sorry for late reply ok guess im stuck then,well it was 59/20 my estimate and for hte first 2 days i was on over 60/20 but its dropped of a lot now,do i phone bt to raise the fault and thanks for the help and advice
well i got a message back from David M
saying
I’ve run a few tests and the results indicate that there is a problems on the network side so I’ve raised a fault,
so will give it a few more days and see how it goes
