Neilfurnival
Message 11 of 17
Re: Not getting the speed i am paying for..
the connection does not drop, it's remained at a stable speed for 2 weeks or more hopeing it would correct its self right upto this point where I have reported it even after switching off (night time) on (morning) cycle.
imjolly
Message 12 of 17
Are you switching the hub off at night and on in morning - or have I misunderstood your post
how is conenction time only 1he in stats?
Neilfurnival
Message 13 of 17
Yes is switch my hub off at night and turn it on again each morning.. then off when the go to work, then on again when I get in from work, however on the night of this post I came in from work later than normal, hence the 1hr uptime.. Sorry for been so brief. my bt app on. my phone now shows my fault. Hopefully it will be addressed soon.. thanks for your help so far.
Keith_Beddoe
Message 14 of 17
That is why you are not getting the full speed. The home hub is intended to be left turned on and connected to the equipment in the cabinet. Disconnections are seen as a fault, and the equipment reduces the connection speed in an attempt to stabilise the line.
It can take many weeks for the speed to recover, provided its left on 24x7.
imjolly
Message 15 of 17
as Keith has said you need to leave hub connected 24/7 - that is what it is disigned for.  neither wonder your connection is not recovering and you have a high noise margin  there is no fault just the constant manual resets as you switch hub off and on causing the DLM to think there is a line fault
Neilfurnival
Message 16 of 17
no worries hopefully it won't melt as it tends to get hot.. lol seems strange tho that may be the problem.. we'll have to wait and see.. thanks again for your feedback..
imjolly
Message 17 of 17
this could now take a few weeks for connection to start to recover but first stage is a stable 24/7 connection with no manual resets
