gomezz
Recognised Expert
Message 1 of 7
Not going to first unread post?
Recently when clicking on the new posts number for a thread it no longer takes you to the first unread post but to the start of the thread.  Probably related is that unread posts at the end of a thread are no longer highlighted as they were before.
Anyone else got this problem?  Any chance of the web master fixing it?
6 REPLIES 6
XRaySpeX
Recognised Expert
Message 2 of 7
Re: Not going to first unread post?
No, goes to 1st unread post when I click on new posts number for a thread or on a its title.
Are you sure you have "Jump to first unread post in a topic" ticked in your Preferences?
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
gomezz
Recognised Expert
Message 3 of 7
No such option showing.
Edit:  Found it.  It was unticked.  So either it is a new option or the web site unset it by itself.
XRaySpeX
Recognised Expert
Message 4 of 7
It's been there ever since I can remember.
gomezz
Recognised Expert
Message 5 of 7
Second case then.
DavidM
Moderator
Moderator
Message 6 of 7
Hi @gomezz and thanks for posting.
Can you access your settings page, it should be under your username on the homepage.
Once there,
  • Access preferences along top menu,
  • Choose Linear ‘Layout’ from sub menu
  • Jump to first unread post in topic is the option you should try
Have you noticed the change all of a sudden? What browser are you accessing the site from?
Cheers
David
gomezz
Recognised Expert
Message 7 of 7
Already found the setting. It was unset which it must have done all by itself a week or so back. Using IE11.
