Message 1 of 6
Novice – how do I post full BT Speedtest results
Hi – I would like to post my full Speedtest results for some feedback on slow BB speed, but I am unsure how to get to all the technical info.
I have run the basic test which has shown slow speeds, but merely copy/paste of the results screen does not show much. Do I have to progress to the Configuration test / change login section before I can get to the detailed tech info (I’m a bit of a novice so I have not tried this last bit yet).
Many thanks
5 REPLIES 5
Message 2 of 6
Re: Novice – how do I post full BT Speedtest results
hi start the speed test select the adsl fibre button wait for the test to complete and then copy and paste the full results shown
Message 3 of 6
and no you do not need the configuration test
Message 4 of 6
Hi John - when I copy and paste the results page, I get :
<script type="text/javascript"></script> Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download  Speed
2989 Kbps
0 Kbps
21000 Kbps
Max Achievable Speed
 Download speed achieved during the test was - 2989 Kbps
 For your connection, the acceptable range of speeds is 4000-21000 Kbps.
 Additional Information:
 Your DSL Connection Rate :13432 Kbps(DOWN-STREAM), 668 Kbps(UP-STREAM)
 IP Profile for your line is - 11850 Kbps
2. Upstream Test: -provides background information.
Upload Speed
283 Kbps
0 Kbps
668 Kbps
>Upload speed achieved during the test was - 283 Kbps
 Upstream Rate IP profile on your line is - 668 Kbps
I expected to see stats on noise and other technical info - there is obviously some BB speed issue as evidenced by the actual / predicted speeds above.
Is this enough or do I need to provide more info (if so, from where !)
Thanks for your help
Message 5 of 6
your download speed is below the acceptable level - I would contact the mods for assistance  http://bt.custhelp.com/app/contact_email/c/4951
Message 6 of 6
Thanks - I have reported to the mods and will report back with developments.
