licquorice
Message 11 of 20
Re: Novice question on infinity -why is my ISP listed as infonet services Corp onBT Infinity?
Hmm, I see what you mean. I wouldn't have thought the header should have contained that information but I'm no expert. I have checked a few headers and I see the same from xxx@btinternet.com addresses but not from other sources. Perhaps somebody else will comment.
licquorice
Message 12 of 20
@camper wrote:
what concerns me is if I send  email via Outlook / Ipad / Iphone - within the header is my public IP address & "name"  the specific machine I'm using . Is this regular ?  I've pasted a header below of an email I sent to my Gmail account & cc to BT account from pc  - outlook.  Then below that header is an email sent from IPAD that contains also, my actual  local /system device IP !?  .  Appreciate your thoughts.
Delivered-To: xxxxx1@gmail.com
Received: by 10.103.118.7 with SMTP id r7csp731338vsc;
        Wed, 11 Jan 2017 04:29:52 -0800 (PST)
X-Received: by 10.84.164.231 with SMTP id l36mr12994311plg.33.1484137792576;
Return-Path: <xxxxxxxxxas@btinternet.com>
Received: from rgout04.bt.lon5.cpcloud.co.uk (rgout0401.bt.lon5.cpcloud.co.uk. [65.20.0.214])
        by mx.google.com with ESMTP id n8si5736027pll.11.2017.01.11.04.29.52
        for <xxxxxx@gmail.com>;
Received-SPF: pass (google.com: domain of @xxxxx@btinternet.com designates 65.20.0.214 as permitted sender) client-ip=65.20.0.214;
Authentication-Results: mx.google.com;
       dkim=pass (test mode) header.i=@btinternet.com;
       spf=pass (google.com: domain of @xxxxx@btinternet.com designates 65.20.0.214 as permitted sender) smtp.mailfrom=xxxxxxx.com;
       dmarc=pass (p=NONE sp=NONE dis=NONE) header.from=btinternet.com
X-OWM-Source-IP: 165.120.xxx.xxx (GB)
X-OWM-Env-Sender: @xxxx@btinternet.com
Received: from ASUS (165.120.xxx.xxx) by rgout04.bt.lon5.cpcloud.co.uk (9.0.019.13-1) (authenticated as xxxxxxxxxx)
        id 58482DA202FD1D49; Wed, 11 Jan 2017 12:29:51 +0000
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed; d=btinternet.com; s=btcpcloud; t=1484137792;
         bh=D9rDWRKrec1BsUITSwHk6FY4NmyjbEBG2CCRUj/urnY=;
        h=From:To:Subject:Date:Message-ID:MIME-Version:X-Mailer;
        b=YVm9Rd68mh/sMpx13r97x57fKwxW2VX/kKlKdzywlH8/8wjnk/woZkLZYsd/FJqL+Ysq14sW8yuxDLGzVRAo2+ePY/CRigORvWr5IE6DXyKzFJ3IdbuBBDJtaOXOvTwLgr91p+mUhblI5OdYwbG8uurnc69T1N8mzBa68YXchYI=
To: <xxxxxxxx.com>, <xxxxxxxxx@btinternet.com>
Subject: outlook
Date: Wed, 11 Jan 2017 12:29:35 -0000
Message-ID: <002701d26c06$67fbe250$37f3a6f0$@btinternet.com>
MIME-Version: 1.0
Content-Type: multipart/alternative; boundary="----=_NextPart_000_0028_01D26C06.67FBE250"
X-Mailer: Microsoft Outlook 15.0
Thread-Index: AdJsBl5DvdBf4oF3RtC4AVvVOAqWLw==
Content-Language: en-gb
------=_NextPart_000_0028_01D26C06.67FBE250
Content-Type: text/plain; charset="us-ascii"
Content-Transfer-Encoding: 7bit
Email from IPAD showing specificdevice IP adress & public IP adress
X-Apparently-To: @xxxx@btinternet.com; Wed, 11 Jan 2017 12:48:24 +0000
Return-Path: xxxxxs@btinternet.com>
Received-SPF: pass (domain of btinternet.com designates 65.20.0.143 as permitted sender)
X-YMailISG: 34OWlvYWLDshGY8D6J8O9c4Z6M_ZWT0GutRk16E3Dyk09zDh
 K79OsNvzb0EG4W0gExoVpaZRscdAS5jwPKg4nQOJ7xkPpODjnFt2NxKXe2Np
 WpGlBdA6jgUMzAP4v2fShfMOyjba.6ovUBsHPUFqUMyEYxkDyZ3ZF8R8636h
 rMnVWerV7eY5HyPt6L5xEbfFBRVHnpAb7sKMDqMR4cGSqBOdUtpIQbJ7KmNc
 kba4TCdjX5KjWdIhlAqnmZnGRZNX1w_Na.upf5tr4YaXPdzN3C6IdbjEMO3s
 ny9c1GRJB2rciAI94dkW7cjgtSwMJGc13FYwB_tqV4rNrIeoQiQw6n2vj9YE
 tngzY6LkkFB4pz_n0z2eB6nUcQ0ra7J.6cLqRyup4XxRDfCfgz744VKj4Mk7
 zOI19DWUv6I2f6LEmyOrKbn626ELA9C37TeyWY_3Y2ev8JbZv4elKr4P3Mrf
 W7gseJCPWq5Q3zGSRSrEuvnFBYYqrH4DcTV4qei8ZIe0XAI1gDlceZK4fJ0A
 VoSbO8Wgt7MftlCFFa_56wWGB1kWoZdMnWC_P169h5XLtzxAJpMnU7MuQoPK
 lwkhT1BJLGk2Re6ii_dLMLyu4FBpIPXqqEtc6whdBC54j60qtBvBTjOyav2R
 4ATu0KmYEZvACiLmit.UcY43mavPLIt7ft.jTnypmztaP7qJOcHsES32MEg1
 8EolGeTNKzh2UY6xr3T4FFzXuN6IYMqCzRXDRJ1PFprr4XfOuhf4CspbA5cn
 j.kgtTMWiQ442ha2EwgLVnTeE6lOz9Gh.64Nc05EbTAw6wUQR8bbQXtBDUeW
 mlm0EwDwT1L32Uwr2JvxiQ6F5NSOq0hOQZH8IdL6DtCZ7IfEpf9yC61nTpWL
 o74yx3TMeRRl5sAVomaJSgU.ICVy0fPR_3.DlOFV.K4.OsgspNQy7RCkt5.D
 FM_1zfp5MajOA5pEm1Ljek9IzvsNLhY9GpfCapdZf8FkZdm.uG1t3zUaGuds
 MXIp57XpTQJ8H0rC63emYoeTS4pfKh4pGl.EYBXIRAaN80e1wmRiMv.uXSMg
 FV_43Td7nlPN6F3bx6TUM7cwB_63WlAb10YXnhtxjAurg7a9ksKNT.mIJHaa
 BtoSaTXsGBfxnkW_lLYHyMbOQyHquP_RX5udP4ClIArPd5VDaDAwfXux29pw
 XNfVbCVHbOPV_zQiLAQknE4__GOV3Ci8f7EPbFBsaGx2DlpMWOJDcSBsAmU4
 Nm_BOyoYYWNLg936rTBnYRyHu7PoN1jPO8GpkW16t.Ac
X-Originating-IP: [65.20.0.143]
Authentication-Results: mta1051.bt.mail.ir2.yahoo.com  from=btinternet.com; domainkeys=neutral (no sig);  from=btinternet.com; dkim=pass (ok)
Received: from 127.0.0.1  (EHLO rgout0703.bt.lon5.cpcloud.co.uk) (65.20.0.143)
  by mta1051.bt.mail.ir2.yahoo.com with SMTP; Wed, 11 Jan 2017 12:48:24 +0000
X-OWM-Env-Sender: @xxxxxx@btinternet.com
Received: from [192.168.x.xx] (165.120.xxx.xxx) by rgout07.bt.lon5.cpcloud.co.uk (9.0.019.13-1) (authenticated as @xxxxx@btinternet.com)
        id 58482FD702F44240; Wed, 11 Jan 2017 12:48:23 +0000
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed; d=btinternet.com; s=btcpcloud; t=1484138903;
        bh=/suxHXZ4o+aGTQdnCOObmwPgThpjZ7fQx5SVSvbcWJw=;
        h=From:Mime-Version:Subject:Message-Id:Date:To:X-Mailer;
        b=C9IZBGFBh7hJjd2E+kYIYC26129IIR+k9hSw7iTf58ApsghhL0loh+PbCJq4ImfaBkojk/HAapgBXXXG1kDxTQ2OaHIEkAcM4Lu/p0DqEZSjYT1JeNNy3T10W4CR3PvqNSausUb209i8zq3oOiHHZRLeDjEUgt6QYP1qZjocnts=
	charset=us-ascii
Mime-Version: 1.0 (1.0)
Subject: iPad out
Message-Id: <9BD7FDD3-5160-4778-887F-979B45144261@btinternet.com>
Date: Wed, 11 Jan 2017 12:48:07 +0000
To: xxxxx <xxxx@gmail.com>,
 Kelvin <xxxxx@btinternet.com>
X-Mailer: iPad Mail (13E238)
Content-Length: 50
Sent from my IPad
@camperI suggest you post the question in a new thread in the email section of the forum as it is more appropriate there and will hopefully receive more attention.
gg30340
Message 13 of 20
licquorice
Message 14 of 20
Thanks gg, getting too old for this !! Smiley Very HappySmiley Very Happy
camper
Message 15 of 20
@licquorice @gg30340  Thanks both, appreciated.
Is it worth me leaving it here or moving/re-posting ?.
Cheers.
licquorice
Message 16 of 20
Might be worth starting a new thread with a more appropriate title on the email board.
camper
Message 17 of 20
Thanks @licquorice .  I had truoble with my settings on that former thread, I think one of the MODS had altered something to merge different but related threads , meaning everything went to the bottom of the thread and potentially didnt get noticed. Anyway that  I can check settings to ensure I can post as a new thread? Cheers.
pippincp
Message 18 of 20
If you are using an email client on your PC/phone then your IP address will always appear in the headers. This is totally normal.
licquorice
Message 19 of 20
Not with Gmail using MSOutlook it doesn't.
Tell a lie, it does!
pippincp
Message 20 of 20
The headers always show the originating machine. For webmail this is the mail server. I you use an email client then it will be your machine.
It's a non issue really.
