Borse2008
Message 1 of 3
OR Modem isnt Gigabit?
Anybody know whether this will ever be upgraded?
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: OR Modem isnt Gigabit?
Given that VDSL2 is only rated up to 100Mbps, does it matter?
Message 3 of 3
VDSL2 is actually capable of 250meg on the 17a profile. Tests have been done with bonded pair to give speeds of up to 400meg over distances up to 300m.
However at the moment it's not an issue and I suspect it'll be at least 12-18 months before the 30a profile is even considered.
