Notsodaftdanny
Message 1 of 5
Old wirig
The BT line from the telegraph pole (replaced about 10 years ago) enters my two storey house at the eaves, goes down in to the loft and then runs the whole length, out the other side through an air vent, down the outside wall and in to the garage and then in to the house and the BT master socket. The run is probably about 100ft and there are few old junction boxes underneath all the loft insulation and boxes in my loft plus the section which is exposed to the elements has lost part of the protective sheath. The wire must be at least 40 years old and rather than replace the existing run, I feel it would be better to re-site the master socket in the room below where the phone wire enters the property. My reckoning is that by cutting out the ancient wire and junction boxes as well as shortening the run I would achieve a more stable broadband signal. I am on fibre broadband and as the crow  flys less than half a mile from. The BT green box. I am prepared to pay for this but would it make a significant difference ?
4 REPLIES 4
imjolly
Message 2 of 5
Re: Old wirig
Think this thread is getting dizzy Smiley Very Happy
i think it you would improve your fibre connection by doing as you have suggested - shortening cable length and cutting out some old junction boxes
Notsodaftdanny
Message 3 of 5
Re: Old wirig
What would BT charge for re-routing the line and installing a new master socket? £130 or so?
pippincp
Message 4 of 5
Re: Old wirig
Around about that price.
Notsodaftdanny
Message 5 of 5
Re: Old wirig
Ok, thanks.
