meridius
Message 1 of 22
Older Home Hub 4 with HG612. Would upgrading to Home hub 6 be better. Help ?
Hi all
Just wanted to ask some Questions as i have the BT home hub 4 with a HG612 openreach modem. Would I benifit from a home hub 6 as i have herd some bt modem/routers can cause less speed than the original older type modem/routers.
I have read that some people see a speed decrese and also herdsome get a littile bit more, the problem is i dont want to get slower speeds so was wanting to know if this is true
thanks
[URL=http://www.speedtest.net][IMG]http://www.speedtest.net/result/2759601729.png[/IMG][/URL]
21 REPLIES 21
Message 2 of 22
Re: Older Home Hub 4 with HG612. Would upgrading to Home hub 6 be better. Help ?
Stay with your Huawei modem and get a third party router would be my advice.
meridius
Message 3 of 22
why is that ?
also what would happen if the HG612 broke down would bt replace it with that same modem or the HH6 ?
imjolly
Message 4 of 22
if your existing setup with separate modem is working ok then I would not make any changes.  if modem stopped working then it an openreach modem not BT so would not be replaced but more likely you would get a HH5
Message 5 of 22
The homehub 5/6 dont connect any faster than the HG612. If you are not happy with the router part buy a proper router
Deathtrap3000
Recognised Expert
Message 6 of 22
My hg612 only synced at 76mbps whereas my hh5 gets the full 80mbps with room to spare.
meridius
Message 7 of 22
thanks for the help.
I have been reading that it depends on the cabinet your on to if you get an improvment but i am not to sure.
Message 8 of 22
Thats correct. If you have been given an HG612 there is a good chance the cabinet is Huawei. Generally ECI works with HH5a and Huawei with HH5b. The HH5 doesn't get any speed benefit on a separate modem.
You can unlock your Huawei and see what is the configuration of your line and check if there is any room for improvement.
meridius
Message 9 of 22
Hi there I checked ny cabinet and i am on a ECI ?
Message 10 of 22
Unlock your modem to see what the stats are before doing anything. I have an ECI for sale of you want it!
