meridius
Message 11 of 22
Re: Older Home Hub 4 with HG612. Would upgrading to Home hub 6 be better. Help ?
Hi all sorry for the lte responce.
would a bt hub 6 be better than what i got now  on a ECI cabinet ? or would replaceing the modem and getting a seprate router be better ? how can i tel whihc modem i have the white sperate one ?
[URL=http://www.speedtest.net][IMG]http://www.speedtest.net/result/2759601729.png[/IMG][/URL]
gg30340
Message 12 of 22
What are you trying to achieve?
Is there a problem with what you have?
Before even considering a HH6 have a read through the forum about some of the problems it has.
imjolly
Message 13 of 22
If your current setup is working ok then I would stay as your are - it it's not broke don't fix it
meridius
Message 14 of 22
Hi all
sorry for not getting back sooner
lets just say my modem only broke would bt replace it with a new HH6 or the same white modem as i am wanting a better router.  lets say i buy a asus router and replace the HH4 i have and later down the line the modem stops working what would i do there ? since bt stoped using the white modem.
thanks
gg30340
Message 15 of 22
If the Openreach modem broke, which doesn't happen very often, you would probably get a replacement Smarthub sent out to you.
imjolly
Message 16 of 22
you may get a smart hub hh6 but more likely a HH5 as a replacement for the hh4 as BT must still have plenty hh5s in stock
meridius
Message 17 of 22
thanks
but how would i then use my asus router if that was the case as it would mean i could not use the asus router which would be a waste of money ?
cheers
imjolly
Message 18 of 22
The modems were openreach not BT  so if modem problem BT now supply hh5 or if lucky hh6 but no longer supply modem. If you want a modem then try auction site
licquorice
Message 19 of 22
If you bought an Asus modem/router you wouldn't need the Openreach modem. If you bought an Asus router and the modem failed, just buy another one on Ebay. Any electronic equipment can fail at any time or work happily for year after year. Why are you crossing bridges before you get to them?
gg30340
Message 20 of 22
@meridius wrote:
thanks
cheers
That would be your problem not BT's. They supply what is needed to get you connected not what you want so that you can connect your own equipment. As imjolly has said, if you want a replacement Openreach modem you can get one easily from ebay.
If you haven't already got the Asus router you could always buy a VDSLModem/router one.
