meridius
Message 21 of 22
Re: Older Home Hub 4 with HG612. Would upgrading to Home hub 6 be better. Help ?
thanks all
do any bt  HG612 white modems work with bt is there no seettings you need to change or are they all just plug and play ?
I am sure i read somwhere that you can still plug a asus router into a HH5 or 6 and disable the router side of the hub and just use it as a modem and plug a router into it, is that true ?
thanks
[URL=http://www.speedtest.net][IMG]http://www.speedtest.net/result/2759601729.png[/IMG][/URL]
licquorice
Message 22 of 22
@meridius wrote:
thanks all
do any bt  HG612 white modems work with bt Yes is there no seettings you need to change No or are they all just plug and play  Yes?
I am sure i read somwhere that you can still plug a asus router into a HH5 or 6 and disable the router side of the hub and just use it as a modem and plug a router into it, is that true ? You can with a bit of faffing about, there is no directly configurable modem only mode, but it is much simpler to use the right box.
thanks
