zulu17
Distinguished Guru
Distinguished Guru
Message 1 of 6
Older Sky Sports recordings
When/if BT cease to provide the Sky Sports via the aerial and card slot  and switch you over to broadband only - will you still be able to play your recordings made previously over the aerial/card system ?
5 REPLIES 5
Robbief
Message 2 of 6
Re: Older Sky Sports recordings
I would of thought u could as their recorded to your visionbox hard drive and will stay there till you delete them. unless there's another major upgrade to the system.
zulu17
Distinguished Guru
Distinguished Guru
Message 3 of 6
Yes they will be on the hard drive but will you be able to play them back sucessfully once Bt stop the existing card based process.  Currently I understand you need an active paired card to playback your Sky Sports recordings.
skappy70
Recognised Expert
Message 4 of 6
Playback of an existing recording isn't an issue.The card pairing is to decrypt the broadcast signal not for playbabck.
zulu17
Distinguished Guru
Distinguished Guru
Message 5 of 6
So what controls whether or not you can view recorded  sky sports (SS)  programs on the new look vision - ?  For example if you ceased Sky sports for a period then your previous recordings were not watchable but remain on the box - after resuming the subscription the recordings were watchable again.  I was advised that this was controlled by the card settings  so I  am just a bit concerned that SS recordings will not be watchable when BT moves away from using the card technology onto broadband.
ChrisC
Message 6 of 6
Unfortunately no, to view a recording requires an active viewing card, same as for viewing live. You can test this by removing your card and trying to watch one of your existing recordings. This is a restriction from Sky, rather than BT.
If there's something you really want to keep you could play it on the box and record it on a separate DVD or VHS recorder.
