Message 1 of 6
On my 3rd HH6 still no good
Upgraded from a problem free HH5 ( infinity 2 ) to the smart hub 6 lasted about 2 months then all 2.4ghz lost connections ,can't option IP address , but iPad and iPhone worked but took ages to connect , reset made no difference.
got replacement all was fine as soon as it was connected , this lasted about 3 months now this one went the same , got my 3rd this week but this time it's the same , if I reboot it worked for about 1hour .
Also each morning the BT to box has lost the internet connection ( wired connections ) and my PC , a reboot gets them going but still no wifi.
After hours waiting and eventually talking to technical help we changed 2.4 channel but this also made no difference , so they are sending me a HH5 , I sent my original back , but I know have three HH6 and I tried my original one which is working ok been on for two hours so far , I'm convinced the thing must be getting too warm and something is failing , how come some get no 5ghz
when mine works on all three.
Anyway the service is shocking I will not be renewing with BT  , the HH6 is not fit for purpose .
5 REPLIES 5
licquorice
Message 2 of 6
Re: On my 3rd HH6 still no good
Whilst I agree that the HH6 is a total disaster, I can't help but wonder why you changed from a problem free HH5.
pippincp
Sage
Message 3 of 6
If it works don't try to fix it!
Message 4 of 6
I believed the hype on TV of it being brilliant and getting wifi while in the garden , it was free also !
TelephoneBob
Expert
Message 5 of 6
If it's on TV it must be true.
gg30340
Message 6 of 6
Just a suggestion:-
