Korinamcintyre
Message 1 of 3
One landline copper plus fibre broadband
I renewed my BT copper contract in April and moved house at the end of May. The speed of wifi in my new house is 1.3mbs
To upgrade to fibre costs £26 per month. New customers get the same package for £18 per month. I'm happy to leave my old copper contract running (as its cheaper than cancelling) but not use it and sign up as a new customer to another provider.
Can I have both fibre and copper and only one landline?
Tags (1)
2 REPLIES 2
john46
Message 2 of 3
Re: One landline copper plus fibre broadband
if you mean copper and fibre broadband on the same line then the answer is no
Webby
Message 3 of 3
By fibre I assume you mean fibre to the cabinet.
If so, you cannot have both ADSL (standard broadband) and VDSL (fibre to the cab broadband) on the same line.
