shirts
Recognised Expert
Message 31 of 38
Re: Ongoing problems with BT Infinity connection and speed
JonDR wrote:
No. The engineer said in the old days he would have gone up and cut it back himself but they are not allowed to now.
I thought that might be the case.....when the engineer fitted a new drop line to my property, instead of climbing up 10 feet up a ladder against the pole, he had to wait for a cherry picker and operator to turn up..........
Hopefully your problems have now been sorted.......
If you found this post helpful, then please click the star on the left, after all, I'm only trying to help........Smiley Wink
ray_dorset
Distinguished Guru
Message 32 of 38
Ok looks like you've identified the problem that you mentioned here:
"2. One of the moderators helping us (Neil) had identified a problem (the reason for this visit) which the engineers could not find today."
You should be able to get max upload but you're only getting 1.8
What product are you on Infinity 1 or Infinity 2?
If not, I'll try again 🙂
shirts
Recognised Expert
Message 33 of 38
@JonDR wrote:
When the broadband engineer left, everything seemed to be working ok and we had a download speed of about 38 (max possible is 40, so we were very pleased).
At a guess, the op is on Infinity 1..........Smiley Wink
JonDR
Message 34 of 38
Yes, we are on Infinity 1.
Ray_Dorset - I'm a bit confused now - do you think we still have a problem? - if so what?
ray_dorset
Distinguished Guru
Message 35 of 38
You're only getting 1Mb upload, you should be getting 10Mb. It may sort itself out 10 days after the fault was fixed, like mine did today.
JonDR
Message 36 of 38
Still confused I'm afraid - why do you think we should be getting 10Mb upload? We were only ever promised a max of 2 when we placed our order for Infinity 1 - see extract from order below:
Your broadband speed
We estimate your download speed will be between 39Mb and 40Mb. We estimate your upload speed will be between 1.9Mb and 2Mb.
The speed test we have been running (BT Wholesale test) shows we are now getting 1.8 upload (was 0.2 before the engineer reset it earlier today).
ray_dorset
Distinguished Guru
Message 37 of 38
As you can see from the dslchecker, you line is capable of 20Mbps up https://community.bt.com/t5/BT-Infinity-Speed-Connection/Ongoing-problems-with-BT-Infinity-connectio...
But if they have put you on the 40/2 product, then everything's fine 🙂
JonDR
Message 38 of 38
That's ok then - thank you all for your help and advice.
Have maintained our speed since the reset yesterday so it's looking good....
Three cheers for the moderators!
