As part of the Halo 1 package I have, as many others will have, the security package included. I notice this is supported by Mcafee. Is it necessary to have any other security package on top of this when the devices we use are only working via BT Broadband
Solved! Go to Solution.
You do need an antivirus product on your devices if you are going to be connecting to the Internet regardless of which Internet provider you are using but I would NOT recommend that you use the BT supplied McAfee product or any product that is a McAfee product.
If you had security products on your devices prior to BT/Halo just keep using that.
