Message 1 of 5
Only getting 100mbps Ethernet
Can anyone assist, I have a BT Smart Hub, use BT Broadband Extender Flex 500 , the fastest speed I get is 100mbps for the ethernet, but yet when I plug it in direct to the Smart Hub it goes to 1.0GBPS. I know the Flex has 500mbps maximum, but I have yet to see this
I have changed the cables to Cat 7, and no joy. Set the speed on my laptop ethernet card to 1gbps, laptop can easily take it, only a couple years old, thinking of getting a new TP-Link extender.
Any thoughts, suggestions?
Regards
Jim.
4 REPLIES 4
Message 2 of 5
Re: Only getting 100mbps Ethernet
The data rate between the two units is 500Mb/s, but the ethernet speed is only [Ports • RJ45 (IEEE 802.3 10 / 100 Mbps)]
See page 2 at https://www.bt.com/content/dam/bt/help/legacy-ug/broadband-and-wi-fi-devices/Broadband%20Extender%20...
Message 3 of 5
Makes sense seeing that got hung up on the 500mbps, guess I need a new extender with the correct port speed.
Thanks for this
Message 4 of 5
I would only replace them if it's actually causing a problem, 100Mb/s is more than enough for BT TV
Message 5 of 5
Also, I think there are a lot of variables when it comes to these extender type things.
I've tried a few with gigabit ports and with relatively new mains wiring in the house, even with testing with sender and receiver units plugged into the same double wall plate, I could only get a maximum of 250 Mbps.
I don't know what experience other people have, but I guess don't be surprised if you do get a pair with gigabit ports and still don't see 500 Mbps.
