slow88
Message 1 of 2
Only getting about 1/2 of line speed. Does this master socket wiring look ok?
Hey guys. Having problems with low speeds. Confirmed via phone that I should be receiving a higher d/l speed after they looked at router stats (only getting 7Mbps - should be closer to 15Mbps), but they are investigating. In the meantime, does the wiring look ok? Is it normal to have that many unconnected wires? Just trying to rule out any issues on my end. Thanks!
1 REPLY 1
imjolly
Message 2 of 2
Re: Only getting about 1/2 of line speed. Does this master socket wiring look ok?
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the adsl stats from your router you may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or if HH4/5 then go to troubleshooting then logs and you are looking for 2 line together when hub last connected to internet and they will show your connection speed and noise margin or if netgear enter 192.168.0.1). Then run  btspeedtester  (MAC users may have problems). when first test completes then run diagnostic test and post the results ( do not reset the router).
are you connected directly via a filter to the NTE5 master or test socket or to somewhere else? Is the master the only phone socket in your home?
You only need wires connected to terminals 2&5  the bellwire on terminal 3 can be disconnected
bellwire removal
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
