Has something changed with the latest version of You View that restricts to only 1 recording? For 2 nights this week including tonight I've tried to set a recording for 9pm but it doesn't let me and doesn't give a message why. Tonight I found 1 additional recording at 9.30 so I cancelled it and the 9pm recording was allowed. When I tried to reinstate the 9.30 the same happened where it wouldn't set and no message why. Could it be the overrun rule for earlier recordings?
Any ideas, I've not seen this behaviour before?
BBC and ITV
first thing to try is a soft reset and if that doesn't clear it a power reset (the first two steps )as described in this post
If you still have the same problem I suggest seeing if you can record the current programme you are watching on say BBC 1 SD ch 1 , then change to a different channel (i suggest on a different mux so ITV SD) ie ch 3 and set that new current should confirm that both tuners are working for recording.
Thanks for the advice. I reset the box last night but I've soft reset the box again and so far I'm recording 2 channels. I've also tested by recording 1 channel and viewing another successfully so both tuners are working at the mo. I'll check again later to see if it's still ok.
