john46
Message 11 of 35
Re: OpenRG is going for reboot by IPC command
the mods only work by invitation should they read your post they will post a link for you to contact them
wilthewiz
Message 12 of 35
Thank you John, I'm aware of that
Oliver341
Expert
Message 13 of 35
I observe an OpenRG reboot exactly every 2 weeks. Home Hub 4, ADSL. It is unrelated to line drops, since the log clearly states the OpenRG is triggering the reboot before the line drop (someone else posted logs here proving this).
Oliver.
Oliver341
Expert
Message 14 of 35
Screenshot of HH4 log when reboot is triggered.
(The firmware version is unchanged from what it was before the reboot, so it's definitely not a firmware upgrade).
Oliver.
wilthewiz
Message 15 of 35
Thanks for the input Oliver. Mine doesn't have a 2 week pattern. Your firmware is same version as mine. Do you know your previous version, guessing ended in .10?
Oliver341
Expert
Message 16 of 35
Yes, I believe the previous version was .10.
Oliver.
wilthewiz
Message 17 of 35
Can you say if you had OpenRG reboots on that version FW?
Oliver341
Expert
Message 18 of 35
I can't remember.
Oliver.
wilthewiz
Message 19 of 35
I'm guessing if you had you would remember it and the fw version 😉
Oliver341
Expert
Message 20 of 35
What can I say, I'm better at remembering numbers than judging the amount of time that's passed. 🙂
Oliver.
