leelee1
Message 1 of 2
OpenReach combined NTE5C and VDSL MK4 Master Telephone Socket - New 2016 version S
How likely is it that bt/open reach will fit one of these OpenReach combined NTE5C and VDSL MK4 Master Telephone Socket - New 2016 version as it would help me as I only have the use of one hand and I have been told that I might have to get to the test socket if something wrong by fibre boardband thanks
1 REPLY 1
Deathtrap3000
Recognised Expert
Message 2 of 2
Re: OpenReach combined NTE5C and VDSL MK4 Master Telephone Socket - New 2016 version S
If the engineer has one, they will generally install one. The older sockets are only screwed on and can be dismantled with one hand. Besides if you only have one socket then there's no difference in using the test socket or the user socket, generally...
