Message 1 of 2
Opening a new tab
Hi,
You used to be able to open an email in another tab by right clicking it. However, that doesn't work now. Or is there another way of showing an email in a new tab without copying and pasting the URL?
1 REPLY 1
Message 2 of 2
Re: Opening a new tab
Presumably you are using the "new" BTMail web page. If that is the case there are no "Tabs" and you can not open more than one email at a time.
You could consider using an email client/app which amongst other options would allow you to open as many emails as you wished.
