CocoPops
Message 1 of 3
Opening the correct ports for ps4
Hello all!
Looking to port forward my ps4, Im a tad confused when adding the ports in....
I had a look at https://portforward.com/bt/home-hub-6/
then a look at http://manuals.playstation.net/document/gb/ps4/settings/nw_test.html
They seem to vary a little
Think this is right
https://ibb.co/myygv5
thanks for the help 🙂
2 REPLIES 2
Liam_
Recognised Expert
Message 2 of 3
Re: Opening the correct ports for ps4
Looks like you have used the correct ports, going by the PS4 info.  So I suppose the question is,  which you haven't answered, does it work?
If not then you might be best getting yourself a good third party modem/router where everything will work as it should.
CocoPops
Message 3 of 3
Seems to work fine so far Liam!
Thanks for the reply!!!!
