Newbie
Message 1 of 3
Openreach Apprenticeship
Does anyone know if there is an age limit for applying to become an Openreach Apprentice? I'm looking for a career change but I'm 29 and not sure whether I would be eligible.
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: Openreach Apprenticeship
Hi
Check the link out http://www.bt4me.co.uk/faqs.html
Edit;
10) Are there any age restrictions?
Only that you need to be of at least minimum school leaving age when you start your Apprenticeship
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 3
Why an apprenticeship?
I'm assuming at the age of 29 you've probably got dependants and/or other financial resposibilities.
The apprenticiship process last months on reduced income. Some of the apprenticies I've spoken to at Yarnfield were there 14 weeks and then had months of buddying to come after that.
Why don't you just apply using the normal channels?
