Message 1 of 18
Openreach database error
Hi. Moved house recently but only broadband option was adsl. Today i manage to talk to openreach field engineer as they were carrying some maintenance opposite the house and he suggested more likely there is some database error. Within 6 semi detached houses connected to the same dp (dp 488) 3 houses shows as fibre available but 3 as exploring option. Considering all on same dp same service should be available??? Is there any way to have it checked/corrected? Thank you
17 REPLIES 17
Message 2 of 18
Re: Openreach database error
Enter your phone number and post results. Remember delete number https://www.btwholesale.com/includes/adsl/adsl.htm
if phone one number won't work use address
Message 3 of 18
Hi. Thank you. I've checked this before and shows adsl only. But as mention engineer we spoke to said this is very strange that despite being connected to the same distribution point as next door neighbours we are not able to get fibre and they can. He mentioned to try to get to someone as hight up as possible in openreach so this can be resolved. All 3 houses with missing fibre are very keen to have upgraded https://gefco-my.sharepoint.com/:i:/r/personal/f005264_gefco_net/Documents/20180214_092722.png?csf=1...
Message 4 of 18
Is it displaying as wbc FTTP for those where it is available?
Message 5 of 18
Yes it does. Within 2 semi detached house 1 can have fibre other adjoining can't hence quering it
Message 6 of 18
You could try calling bt’s Fttp sales team on 0800 587 4787 and explain the situation. They may be able to help.
Message 7 of 18
Make sure it's FTTP and not FTTPoD as they are 2 entirely different products.
Message 8 of 18
Please see attached. It seems our house shows as connected to different exchange. Would this be possible despite same distribution point? And yes this is FTTP
Thank you for all your help
Message 9 of 18
From the second screenshot it looks like the neighbours are on fttc (vdsl) as opposed to FTTP. FTTP on demand is a different product as mentioned above. Which cabinet and exchange are the results displaying
Message 10 of 18
I've tried FTTP team but no luck. Our house shows cabinet 14 (Tile Hill), next door cabinet 4 (Tile Hill)
