Message 1 of 5
Openreach modem
Hi all I'm looking for information regarding the openreach modem, I'm currently on infinity 2 my speed was 72/19 but recently my speed dropped to 58/19 as my hh5 reboots after 14 days and has done the last 3 times so I now use a openreach modem, my question is will the modem reset it self automatically if my dlm profile changes or do I wait a couple of weeks then power cycle the modem, any info would be much appreciated.
thanks
4 REPLIES 4
Message 2 of 5
Re: Openreach modem
No intervention is required. DLM will reboot as necessary.
Message 3 of 5
Re: Openreach modem
Thanks for your reply but could DLM reboot an unlocked modem?
Message 4 of 5
Re: Openreach modem
Yep, the DSLAM causes a re-sync rather than actually re-booting the modem.
Message 5 of 5
Re: Openreach modem
Cheers thank you
