ChrisB
Expert
Message 1 of 36
Openreach where and when website
Can either a moderator or an expert explain the Openreach database. If I put in my postcode and then house number it says accepting orders (AO) for fibre. If I put in my phone number the pin has a question mark. I cannot order fibre.
I live within 500m of the exchange with (almost) maximum speed ADSL so it's not an issue with copper line length or quality. It seems unlikely that there are two cables to the distribution pole since it only serves four properties. It could be an exchange only line but why doesn't the full, down to house number, postcode checker show this?
This seems to me to be baffling.
35 REPLIES 35
pippincp
Sage
Message 2 of 36
Re: Openreach where and when website
The postcode checker is not 100% accurate as a postcode can be served by one or more cabinets as well as EO lines so merely gives a generalised result.
The telephone number checker knows exactly how you are connected and what you are able to get.
ChrisB
Expert
Message 3 of 36
So what's the point of the postcode checker down to individual property address if it gives a meaningless answer?
shirts
Recognised Expert
Message 4 of 36
Can you put your telephone number into http://www.dslchecker.bt.com/adsl/adslchecker.welcome and post the results (after removing your telephone number) ?
If you found this post helpful, then please click the star on the left, after all, I'm only trying to help........Smiley Wink
imjolly
Message 5 of 36
it does not give a meaningless answer just an approximate answer and is helpfull as a guide  for people moving home and nowadays internet connection is important - as long as you bear in mind that as it says the most accurate is phone number
ChrisB
Expert
Message 6 of 36
It is meaningless. Someone moving to this house would think they could get a fibre service and they can't at the moment. Quite rightly they'd be pretty disappointed if they based a decision about their choice of house on this checker. I understand down to postcode level but I'm talking about down to individual address level as being meaningless. I think Openreach should improve their checker or just leave it at postcode level.
imjolly
Message 7 of 36
what do you get if you enter your phone number in the dslchecker
gg30340
Message 8 of 36
A post code checker will give you a broad estimate of what is available in the general area. An address check will give you a narrower estimate of what is available for that address and a telephone check will give you the most accurate estimate of what the property will get.
Perhaps you know of a better way of supplying what may be available to a potential house purchaser if the property they want to purchase does not have a telephone line or would it be better just to say, No idea, take a guess.
EDIT: As regards your line I suspect it is an Exchange Only line. To confirm this you should do the check as suggested.
ChrisB
Expert
Message 9 of 36
Surely an address check should be accurate (an address only has a single phone line into it after all) and not just give "a narrower estimate". There is no point in doing this other than to give a false impression of the line's capabilities, perhaps this is what Openreach are deliberately doing.
My HH5 suggests the line actually runs at 19.8/1.1Mbps and I'm sure is exchange only currently.
gg30340
Message 10 of 36
As has been pointed out, an address check should only be done if there is no BT phone line at the property. If there is no phone line, the address checker is only giving an estimate based on the average for the properties in that street. There is no way known to man that you could be given an accurate estimate to a property that does not have a phone line.
