Message 1 of 1
Orbi RBK753 with BT TV - IPC 6023 error
I have BT Broadband FTTP and run the Netgear Orbi RBK753 system (aka. RBR750). I am looking to use BT TV with the system, but receive the error IPC6023 when i try to access multicast channels.
Is anyone clear on how to get BT TV working with the Orbi system?
Orbi supports, in theory, IGMP Proxying - and the option 'Support BT IGMP Proxying' is enabled. The BT TV box is direct connected over Ethernet to the Orbi, and the identical setup works with a Smart Hub 2.
Any advise would be much appreciated - especially if you have the same system and have got it working!
