davidc3
Message 1 of 3
Order date changed, now worried about topcashback
Hello
We had Phone, broadband & tv package whick arrived yesterday (23rd sept). The activation date was yesterday & an openreach engineer came & installed a phone line. The broadband doesnt work, theyre sending another hub next week.
I notice theyve changed the completion date to the 27th sept.
I've read some posts on here about BT using this date change to avoid paying out on Topcashback
Is there anything I can do to  try & avoid this?
2 REPLIES 2
JohnC2
Moderator
Moderator
Message 2 of 3
Re: Order date changed, now worried about topcashback
Hi @davidc3 As long as you order was submitted via Topcashback correctly once all of your order completes they will be able to track it successfully when you claim your cashback.
Cheers
John
davidc3
Message 3 of 3
Thank you for your reply
Its showing in Topcashback as pending, I'll keep an eye on it
many thanks
David
