Message 1 of 5
Ordered fttp should I buy a router
Hi every one I’ve just ordered bt full fibre 900 but I’ve read so many people saying the smart hub 2 WiFi is hopeless for these faster speeds would you recommend I buy a new router to replace the smart hub 2
4 REPLIES 4
Message 2 of 5
Re: Ordered fttp should I buy a router
Why not wait and see how the hub performs and then make the decision.
Message 3 of 5
I’ve read that the smart hub 2 doesn’t have WiFi 6 is that true?
Message 4 of 5
Yes, it's true, it doesn't.
Message 5 of 5
I asked myself the same question a month ago.
Bought myself a new Asus RT-AX88U Router (WiFi 6 ready) so start the upgrade plan now.
Also fitted the Killer WiFi 6 network cards to both my Laptops so I'm ready for the upgrade when it happens in the next month hopefully.
Better WiFi than the Smart Hub 2 and according to reports it works with the latest 900 package no issues.
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
