j-whitney
Message 1 of 4
Other voices on the line
A few days ago I picked up the phone and I could hear very quiet and faint voices talking. I think it was my neighbour? But it hasn't happened since? I was wondering if this has happened to anyone?
___________________________
3 REPLIES 3
Distinguished Guru
Message 2 of 4
Re: Other voices on the line
The chances are that it is a fault on the incoming telephone line known as overhearing.
You will need to report this to whoever provides your phone line (BT call 0800 800 151) It could be that when they test the line they will not be able to see an apparent fault. If you know your neighbours phone number give this to the advisor who takes the fault
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
ronin22
Message 3 of 4
"The chances are that it is a fault on the incoming telephone line known as overhearing"
gosh did EINSTEIN suggest that.  Smiley Very Happy
In the end we will all be star dust.
Then start all over again.
Distinguished Guru
Message 4 of 4
Sarcasm I believe is the lowest form of wit!!!! at least I got a rating for the replyMan Tongue
