Ianlaw
Message 1 of 2
Outlook Express fault: Not finishing downloading new messages:Error Ox800CCCOF
My Outlook Express stopped working properly a couple of days ago.
Opens OK, but then fails to complete the downloading of my new messages/e-mails.
The following error message is produced:
Your server has unexpectedly terminated the connection. Possible causes for this include server problems, network problems, or a long period of inactivity. Account: 'mail.btinternet.com', Server: 'mail.btinternet.com', Protocol: POP3, Port: 110, Secure(SSL): No, Error Number: 0x800CCC0F
Can anyone suggest a solution?
I have been in touch with Technical Help, but they seemed unable to assist and I ran out of time, so was unable to conclude the "Help" session.
1 REPLY 1
Andy_N
Distinguished Guru
Message 2 of 2
Re: Outlook Express fault: Not finishing downloading new messages:Error Ox800CCCOF
Hi. Welcome to the forums.
The problem is usually one of two things, either an account access problem - possibly fleeting, but can last a few days - alternatively somethin is interferring with the connection, possibly a firewall or security product. If the latter, check something called "Email scanning". If this is on, turn it off for both receive and send.
You might also like to try a specific receive request in OE by clicking the down arrow and choosing the option.
Another thing might be a corrupt email, causing OE to have an access failure. The usual way to check this is to login to webmail via a browser and see what's in the Inbox. You can then move them all (or just the "top" one) into a temporary folder - moving them back one at a time into the Inbox and retrying OE.
