Message 1 of 10
Outlook for Android issues: "error adding recipient to message"
Hi,
Until recently, Outlook for Android was a working client.
Then suddenly, when trying to send or reply to an email, the following error happens:
Tried:
1) reset app
2) remove and reinstalled app
3) full factory reset of phone
4) IMAP and SMTP settings are correct
Also:
5) Outlook client works fine on Windows 10.
6) GMAIL for Android works fine (i do not want to use GMAIL)
7) no issues with username or password.
😎 new BT Mail app not compatible (presume due to yahoo mail).
thanks,Richard
9 REPLIES 9
Message 2 of 10
Re: Outlook for Android issues: "error adding recipient to message"
If Gmail works fine, the problem is clearly with Outlook.
Try Blue Mail
Message 3 of 10
on that basis, no one would be working with outlook?
Blue Mail seems to work ok too.
Message 4 of 10
If your mail works fine with multiple other apps, where do you think the problem must lie if not with Outlook?
Has there been a recent update to Outlook?
Message 5 of 10
Hi I have been having the exact same problem which started 5 days ago. I messaged microsoft and they said they are aware of this issue and will fix in the next version with no approx date. I tried removing and reinstalling and it still doesn't work. All works fine from my husbands email account, the problem is just with mins.
Message 6 of 10
Hi, I have had this problem for several months now,  have tried de-install/re-install etc, nothing works.  At a loss...don't want to use another email.
Message 7 of 10
Not sure what you mean by not wanting to use another email. No need to change email address just use a different app.
Message 8 of 10
Sorry, should've said that I like Outlook...old fashioned I guess!
Message 9 of 10
Same Issue with wife's phone. not mine ( we both have same phone Samsung Galaxy S20+ 5G.  The only thing different I can see is that an update occurred for the phone this morning. and the Email was working fine yesterday. I'm sure that something in the update happened. ~ logically.. my 3 cents
Message 10 of 10
Just a quick note, my phone (working) the app Version 4.2136.1 (Outlook) and Not working is version 4.2136.2
