Shoveitpusher
Message 1 of 4
Overheating you view box
We are on our second box. The first stopped working and seemed very hot. This one has started cutting out after around an hours watching.
i put a thermometer on it today and on standby, it is running at 42.5 degrees Celsius, which seems a bit high. Ambient temp is 24 degrees.
Any ideas what these boxes should reach?
3 REPLIES 3
jam2000
Recognised Expert
Message 2 of 4
Re: Overheating you view box
Not sure about the temps, but have you got enough air flow around the box and havent got anything on top or underneath it?
Shoveitpusher
Message 3 of 4
On a shelf next to the wifi router. Nothing above or below
Martyfp68
Message 4 of 4
My UHD box was constantly getting hot, even when in standby Smiley Frustrated
I bought a set of small rubber feet off of amazon and they raise the box slightly and help with the airflow. It still runs hot, although better than before.
