Message 1 of 3
Own Ubiquity Router FTTP
Can Somone help me get connected using PPPoe and what are the login details I'm using DJM PRO and have FTTP connect direct from Lan port on white incoming box
2 REPLIES 2
Message 2 of 3
Re: Own Ubiquity Router FTTP
You should be connected to the WAN port on your router
Message 3 of 3
PPPoE username is [email protected] password not needed but if router requires you to enter one, just use BT.
