Message 1 of 1
PC to TV via Smart Hub 2/CAT5e
The  upstairs wifi PC is OK. The downstairs Hub is plugged into the Series 5 Samsung and all internet connections
(Gateway ,Ping, etc...). are OK . The TV shows up on PC devices list. PC wifi shows it is  enabled and shared
IPv4,IPv6, OK. Local Area connection enabled but no IPv4,6, gateway, server etc...  no packets received?
On the smart hub web page the details for the TV says this device does not support IPv6. And no port forwarding
has been set up?  Ethernet, WAN miniport, bluetooth, broadband on the PC  screen all show as switched off?
Reply? Keep it simple.
