craigyg1987
Newbie
Message 1 of 14
PC won't go wireless
Help!!!!!!!!
I have set up my xbox, my fiances iphone and my iphone and both our kindles wireless with not problem. But i can't seem to get my PC to go wireless i've never had any trouble in the past, (i.e connecting to wireless thru PC) before. I'm getting frustrated now, everytime I try to a message comes up say 'Wireless Authentication Error' the asks me to diagnose the problem, my wireless network adaptor is compatible as I have checked
Can anyone help me out please
13 REPLIES 13
Message 2 of 14
Re: PC won't go wireless
Hi have a look at this link it may help you also have you checked you are using the correct wireless security code
http://www.btinternet.com/~cbeddoe/wireless/hub3_wireless.html
Message 3 of 14
did you install the bt cd?  if so I suggest you uninstall it and let windows manage your wifi connections as BT cd is known to cause wifi problems
craigyg1987
Newbie
Message 4 of 14
hi yes I have checked I'm using the right code as it's the code i used for xbox kindle etc
craigyg1987
Newbie
Message 5 of 14
if I uninstall it, will i knock my xbox etc, off aswell?
Message 6 of 14
no it will not affect the xbox uninstall the disk and let windows find the wireless network
craigyg1987
Newbie
Message 7 of 14
i would like to point out that i am currently running my internet thru my ethernet cable, so am connected to the internet, just annoying that I can't get it Wireless
Message 8 of 14
the most secure and fastest service will always be with a wired connection
Message 9 of 14
I am surprised as a gamer you are using wireless and not ethernet which gives a better more stable connection
craigyg1987
Newbie
Message 10 of 14
what should my encryption type be AES or TKIP?
