Message 1 of 7
POE(Power Over Ethernet) Problems
Hello, i recently switched over to Bt infinity, everything at the moment is great. But on my old internet on the router i was getting to the router by POE. As soon as we got to BT Infinity, for some reason every 2 minutes it cut out for about a minute. I switched to wireless and it's been fine. Unfortunatly i have a lot of devices that seem to interfere with it and bringing the signal level down. I tried putting the POE's back in but they dont seem to be able to connect to the internet at all.
I'm using the Home Hub 3, any reason why it may not be working?
Thanks!
6 REPLIES 6
Message 2 of 7
Re: POE(Power Over Ethernet) Problems
Power over Ethernet means sending DC power over your Ethernet cables. Perhaps the home hub 3 is short circuiting the power supply unit?
Message 3 of 7
Do you mean powerline adaptors (homeplugs)?
Message 4 of 7
Yeah, the ones where you plug the ethernet into the power socket, one at the pc and one at the router
Message 5 of 7
Try resetting them, most have a reset function. You might just need to "re-pair" them.
The installation of Infinity couldn't have had an affect as ultimately, the powerline adaptors don't know nor care what speeds, or what type of internet connection there is. In fact, they're designed to connect 2 devices over Ethernet, which doesn't mean there has to be an internet connection involved.
Message 6 of 7
Doesn't have a reset function, just plug in and turn it on.
85Mbps Powerline Ethernet Adapter
MODEL: NL-HPDUAL
Message 7 of 7
I managed to get it working but the connection keeps dropping every minute or so... weird
