Message 11 of 15
Re: PPP Authentication problems on 2701HGV-C. Never had this before but internet unusable.
as you are on ADSL2+ your IP Profile changes automatically an SNR reset may increase your speed slightly as to the business hub there is no technical support offered on residential lines although it does work
Message 12 of 15
Ok thanks guys, so if my profile changes automatically, what is the downstream rate cap of 576kbps that the hub is reporting? It clearly is limiting me as 88.2% of 576 is the same value as connection rate I'm getting, despite syncing at over 900kbps.
Message 13 of 15
looks through your previously posted stats and can't fins any menyion of 576 rate cap
Message 14 of 15
That's because I never posted it, here:
DSL Diagnostics - Training History Physical Line 1 General Information
DSL Line (Wire Pair):Line 1 (inner pair)
Downstream Rate Cap:576 kbps
Downstream Atten. at 300kHz:80.7 dB
Uncancelled Echo:-20.1 dBOk
VCXO Frequency Offset:-41.7 ppmOk
Final Rx Gain:29.9 dBOk
Excessive Impulse Noise:0Ok
Downstream Required Impulse Noise Protection:5
Downstream Impulse Noise Protection:8.06
Downstream Delay of Latency Path:7.38 ms
Upstream Impulse Noise Protection:0.70
Upstream Delay of Latency Path:5.27 ms
Framing ModeATM
Message 15 of 15
Seems like they did it! My limit has been removed check it out. I still don't fully understand how they were limiting me on 21CN.
Downstream Rate Cap:16352 kbps
Downstream Atten. at 300kHz:79.3 dB
Uncancelled Echo:-18.2 dBOk
VCXO Frequency Offset:-42.1 ppmOk
Downstream Required Impulse Noise Protection:4
Downstream Impulse Noise Protection:0.00
Downstream Delay of Latency Path:0.73 ms
Upstream Impulse Noise Protection:0.00
Upstream Delay of Latency Path:0.25 ms
Framing ModeATM
DSL DetailsDown Up
Modem Type:Built in modem - ADSL
Current DSL Connection:
Rate:1056 kbs288 kbs
Max Rate:1045 kbs288 kbs
Noise Margin:6.0 dB6.0 dB
Attenuation:63.0 dB49.0 dB
Output Power:15.3 dBm12.4 dBm
Protocol:G.DMT2 Annex A
Channel:Fast
DSLAM Vendor InformationCountry: {46336} Vendor: {IFTN} Specific: {48753 }
ATM PVC:0/38
Rate Cap:1045 kbs
Attenuation @ 300kHz:63.0 dB
Uncanceled Echo:-18.2 dBOk
Final Receive Gain:29.9 dBOk
