SeeK
Message 1 of 12
PPPoE information for Infinity
Engineer came around today and got my Infinity connection up and running and the speed is fantastic (38/1.7 Mbps), but I have a question. I don't want to use the Home Hub as I have a Linksys E3000, so what I need is the PPPoE information for my connection.
In the HH's settings, it just says bthomehub@btbroadband.com with no password, which I can't enter in the E3000 (it asks for a password). So I wonder, how can I set this up and where is the "correct" PPPoE information?
11 REPLIES 11
Message 2 of 12
Re: PPPoE information for Infinity
have you tried just using a space as the password?
SeeK
Message 3 of 12
Just did, it won't accept it. 😞 Perhaps Linksys didn't consider this scenario when they wrote the E3000's firmware. So there really is no password?
Message 4 of 12
there is no password on the hub so anything as the password will be accepted as sign in.  My netgear is the same but it does accept a space as the password
MikeL
Message 5 of 12
Just try password as the password
Regards Mike
daleski75
Message 6 of 12
I got my Belkin router to work with PPPoA and PPPoE by using my @btinternet.com username and password so it might be worthwhile giving that a go as well.
wedd1ng528
Message 7 of 12
I did exactly the same as daleski when I set up my Vigor 2820n for Infinity (well ,I did use my own username and password - not daleski's!) and it works just fine.
wedding
Mistakes and embarrasing goofs in e-mails are only discovered when you've sent them!
SeeK
Message 8 of 12
Alright chaps, I'll give my @btinternet.com details a try tomorrow. I'll let you know how it goes. Cheers!
SeeK
Message 9 of 12
Just an update: Using my @btinternet.com username and password works just fine. Thanks! 🙂
Starman
Message 10 of 12
Thanks guys - just the infomation I was looking for. Now I know I can use my Billion 7800N once my Infinity is installed as I really prefer not to use the HH 🙂
BT Infinity (EASTF) 58.93/15.94 Mbps [IP Profile: 60.8/20 Mbps] using Openreach Modem & Billion BiPAC 7800N
