Soultrap102
Message 1 of 9
PS3's suddenly not working on Ethernet.
PS3's suddenly not working on Ethernet. pc's work fine.
i will add the info i can give.
Jun 15 19:20:05 2012(345522.090000) Admin login successful by 192.168.1.5 on HTTP
Jun 15 18:49:34 2012(343690.670000) Admin login successful by 192.168.1.5 on HTTP
Jun 15 15:50:31 2012(333026.850000) sock_socket: failed bind() for ip 0.0.0.0 port 64275: Address already in use
Jun 15 14:42:24 2012(328940.160000) Socket error
Jun 15 12:12:26 2012(319942.410000) HTTP server returned error 404
Jun 15 03:43:18 2012(289394.090000) Socket error
Jun 14 23:44:43 2012(275079.580000) Admin login successful by 192.168.1.5 on HTTP
Jun 14 09:09:37 2012(222662.470000) Socket error
Jun 14 07:52:37 2012(218042.860000) Socket error
Jun 13 22:55:13 2012(185798.870000) sock_socket: failed bind() for ip 0.0.0.0 port 3240: Address already in use
Jun 13 22:18:49 2012(183615.040000) Jun 13 22:18:49 [74]: l2tpd: Error: Invalid length field 33155 greater than received datagram size 103
Jun 13 22:00:51 2012(182536.500000) HTTP server returned error 400
Jun 13 22:00:46 2012(182531.750000) Socket error
Jun 13 21:57:51 2012(182356.620000) HTTP server returned error 400
Jun 13 20:44:54 2012(177979.710000) Socket error
Jun 13 20:18:12 2012(176377.920000) sock_socket: failed bind() for ip 0.0.0.0 port 5062: Address already in use
Jun 13 19:38:46 2012(174012.280000) sock_socket: failed bind() for ip 0.0.0.0 port 34910: Address already in use
Jun 13 19:30:37 2012(173523.070000) sock_socket: failed bind() for ip 0.0.0.0 port 5060: Address already in use
Jun 13 17:57:17 2012(168001.630000) HTTP server returned error 400
Jun 13 17:55:59 2012(167923.770000) HTTP server returned error 400
Jun 13 17:54:56 2012(167860.780000) HTTP server returned error 404
Jun 13 12:23:36 2012(147981.420000) Socket error
Jun 13 10:53:23 2012(142568.200000) Socket error
Jun 13 09:32:31 2012(137715.770000) HTTP server returned error 404
Jun 13 08:29:31 2012(133936.180000) Admin login successful by 192.168.1.5 on HTTP
Jun 12 17:56:37 2012(81655.460000) HTTP server returned error 404
Jun 12 17:18:19 2012(79356.720000) WGET: Error connecting to host http://192.168.1.5:2869/upnp/eventing/mfacguowqf (192.168.1.5:2869)
Jun 12 14:38:26 2012(69764.390000) Socket error
Jun 12 14:18:32 2012(68570.500000) HTTP server returned error 404
Jun 12 11:14:37 2012(57534.980000) WGET: Error connecting to host http://192.168.1.6:2869/upnp/eventing/haucoelcig (192.168.1.6:2869)
Jun 12 09:34:22 2012(51519.970000) HTTP server returned error 404
Jun 12 08:28:11 2012(47549.540000) HTTP server returned error 400
Jun 12 08:18:11 2012(46948.850000) HTTP server returned error 400
Jun 12 08:18:07 2012(46945.430000) HTTP server returned error 400
Jun 11 20:45:07 2012( 5364.600000) Socket error
Jun 11 19:17:31 2012( 109.520000) WGET: Error connecting to host http://192.168.1.6:2869/upnp/eventing/ihkgpecakz (192.168.1.6:2869)
Jun 11 19:21:04 2012( 81.990000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Jun 11 19:20:44 2012( 61.620000) HTTP server returned error 400
Jun 11 19:20:39 2012ERR 2003-01-01T00:00:35Z cwmp: mt_cwmp: session error: Could not resolve host
Jun 11 19:20:39 2012( 56.630000) WGET: Error connecting to host http://192.168.1.6:2869/upnp/eventing/uepicodjgm (192.168.1.6:2869)
Jun 11 19:20:12 2012( 30.120000) DVA started
Jun 11 19:20:11 2012( 28.780000) sys_if_stats_reset failed for atm0
ADSL line status
Connection Information
Line stateConnected
Connection time3 days, 23:58:28
Downstream6,779 Kbps
Upstream1,083 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.5 Annex A
Latency typeFast
Noise margin (Down/Up)11.1 dB / 6.4 dB
Line attenuation (Down/Up)41.3 dB / 20.3 dB
Output power (Down/Up)9.7 dBm / 1.6 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)3305 / 0
HEC Errors (Down/Up)9585 / 0
Error Seconds (Local/Remote)2244 / 0
8 REPLIES 8
Soultrap102
Message 2 of 9
Re: PS3's suddenly not working on Ethernet.
anyone got any idea?
john46
Message 3 of 9
have you tried restarting the PS3
Soultrap102
Message 4 of 9
yes i have. i have tryed factory reset, connecting direct to HH, wireless and ethernet both dont work ive tryed it on other ps3's same problem. and my ps3 works fine at my friends house.
thanks for responce.
Soultrap102
Message 5 of 9
I have contacted the mods but I don't think they got my email.
Soultrap102
Message 6 of 9
not a broadband issue lol. ive got no broadband or internet on my ps3 or it has (broadband connection issuses).
Keith_Beddoe
Message 7 of 9
The broadband speed and connectivity board is primarily for people who cannot establish an ADSL connection, or their ADSL connection is slow.
In your case, your broadband itself is fine, as your PC can connect. So this issue is with your hardware, so you are more likely to get help on this board, whch is described as
"This board is for everything else related to broadband in your home: emails, tech setup, PCs and other hardware"
Soultrap102
Message 8 of 9
I see your point. Any ideas or are there any mids on?
Soultrap102
Message 9 of 9
Mods^
