Message 1 of 11
Packet loss/Low speed
1. Product name:BT Home Hub
2. Serial number:+068543+NQ51208267
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 10/07/15
4. Board version:BT Hub 5A
5. DSL uptime:3 days, 15:50:34
6. Data rate:19999 / 79906
7. Maximum data rate:33755 / 93552
8. Noise margin:15.6 / 9.1
9. Line attenuation:18.8 / 16.1
10. Signal attenuation:19.0 / 16.1
11. Data sent/received:
8.6 GB / 167.6 GB
http://i.imgur.com/F1rcuop.png
http://i.imgur.com/nlMElNs.png[/img]
http://i.imgur.com/7GX8OJ3.png[/img]
10 REPLIES 10
Message 2 of 11
Re: Packet loss/Low speed
was the speedtest carried ou using a wired connection
Message 3 of 11
got this now. It seems to be evenenings where the net drops, I understand that speeds go down during peak but by that much? Ping also go up, A good amount of packetloss.
http://i.imgur.com/TCQYKDU.png
Message 4 of 11
Message 5 of 11
Can you please post a traceroute to bbc.co.uk
Message 6 of 11
Message 7 of 11
Your throughput is so low that I can't understand how BT isn't noticing that there are congestion problems (oh wait, BT never notices congestion problems) with the backhaul that need to be reported to them. I think @john46 or @imjolly will be able to provide the number that you need to use to report the congestion problem.
Moderator
Moderator
Message 8 of 11
Hi opalfruitfish,
I'm sorry to see you're having issues with your BT Infinity. Please use the 'contact the mods' link in my forum profile under the 'about me' section to send in your details. You can find the link by clicking on my username.
Neil
Message 9 of 11
Can anyone help me, I've to change my username and password to do the part 3 speedtest but I have no idea how to change my username
http://speedtest.btwholesale.com/
Message 10 of 11
I just wanna be able to use my internet during the evenings.
Microsoft Windows [Version 10.0.10240]
(c) 2015 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.244.18]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  BThomehub.home [192.168.1.254]
  2    95 ms    95 ms     *     217.32.142.199
  3    97 ms    96 ms   103 ms  217.32.142.238
  4   100 ms   101 ms   103 ms  212.140.206.194
  5   105 ms   105 ms   102 ms  213.120.162.65
  6   103 ms   102 ms   103 ms  31.55.165.107
  7   102 ms    99 ms     *     109.159.250.56
  8   108 ms   108 ms   108 ms  109.159.255.147
  9   110 ms   105 ms   109 ms  peer2-xe7-0-1.telehouse.ukcore.bt.net [109.159.252.41]
 10   107 ms   109 ms   108 ms  194.74.65.42
 11     *        *        *     Request timed out.
 12     *        *        *     Request timed out.
 13   109 ms   108 ms   108 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
 14   109 ms   108 ms   109 ms  132.185.255.149
 15     *      112 ms   111 ms  fmt-vip72.telhc.bbc.co.uk [212.58.244.18]
Trace complete.
http://i.imgur.com/NfZ67fG.png
I have been in contact with someon from here for about 3 months to no success, I was told  that the suppliers had found an issue on my line on 17/09 and the work would be done before  15/10. The work hasn't been done and wasd told 'I am waiting for an update from our suppliers about the work being done at your exchange. I should hear back from them within the next few days so once I get an indication as to what the next steps are I will be in touch'. Who can I chase up to get this sorted?
