kevin_mcq
Message 1 of 8
Painfully slow connection with new master socket
Hi forum
Hoping for some advice or perspective on possible issue with my broadband connection. Perhaps unrelated, but I recently had a new master socket fitted (NTE5), however the broadband speed in the house is now painfully slow.
Am using BT Home Hub 4, below are the rest results I'm receiving, however I'm curious as to whether 0.25Mbps really is likely to be the maximum achievable speed, as this renders several services almost unusable.
Grateful if anyone feels there is more that could be done.
Thanks,
Kevin
Results....
The only socket connected is for the router/ phone, which is now connected to the test socket (with a microfilter).
Quiet line test: normal
Speed info from the hub manager (normal socket/ test socket)
Download speed (Mbps): 0.17 / 0.24
Upload (Mbps):                0.03 / 0.02
Ping latency (ms): 326.50 / 0.00
ADSL connection (from home hub)
12:02:59, 29 Jun.
(334146.810000) DSL noise margin: 16.50 dB upstream, 10.60 dB downstream
12:02:58, 29 Jun.
(334145.900000) DSL line rate: 440 Kbps upstream, 284 Kbps downstream
Speed test (from BTW performance test)
1. Best Effort Test:  -provides background information.
Download  Speed
0.17 Mbps
0 Mbps
0.25 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.17 Mbps
 For your connection, the acceptable range of speeds is 0.1 Mbps-0.25 Mbps.
 IP Profile for your line is - 0.25 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
0.03 Mbps
0 Mbps
0.83 Mbps
Upload speed achieved during the test was - 0.03Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit the FAQ if you are unable to understand the test results.
From kitz.co.uk max speed calculator
Estimation of your maximum rate adaptive adsl speed
Downstream
Attenuation
 0 dB
Approx
Line Length
0 km
From BT Diagnostics site:
Broadband Speed Test
We haven't been able to complete the speed test at this time.
This may be due to a problem with the speed tester, or your line may be running very slowly.
7 REPLIES 7
imjolly
Message 2 of 8
Re: Painfully slow connection with new master socket
can you enter your phone number and post results  remember to delete phone number  https://www.btwholesale.com/includes/adsl/main.html
your connection time is only 12 today was that a manual reset or router dropping conenction?  have you been resetting the router or has it been dropping connection or both?
john46
Message 3 of 8
your noise margin is high because of a number of disconnections this will reduce your connection speed also your connection time is low is this due to the hub dropping connection or a manual restart
kevin_mcq
Message 4 of 8
Thanks for your quick response, much appreciated. Further results below - suggesting that faster should be possible?
The connection time from 12 was due to a manual reset, the only time it was reset (WAN logs also noted below).
ADSL Checker....
Telephone Number 01562xxxxxx on Exchange WOLVERLEY is served by Cabinet 3
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
WBC ADSL 2+Up to 13.5--11.5 to 15Available
WBC ADSL 2+ Annex MUp to 13.5Up to 1.511.5 to 15Available
ADSL MaxUp to 8--7 to 8Available
WBC Fixed Rate2----Available
Other Offerings
Copper Multicast------Available
12:02:59, 29 Jun.(334146.810000) DSL noise margin: 16.50 dB upstream, 10.60 dB downstream
12:02:58, 29 Jun.(334145.900000) DSL line rate: 440 Kbps upstream, 284 Kbps downstream
12:01:36, 29 Jun.(334063.890000) DSL is down after 2226 minutes uptime
12:01:36, 29 Jun.(334063.890000) ETHoA is down after 2226 minutes uptime
12:01:36, 29 Jun.(334063.550000) PPPoA is down after 2226 minutes uptime [Waiting for Underlying Connection (WAN DSL -​ Up)]
12:01:33, 29 Jun.(334060.470000) PPP LCP Send Termination Request [User request]
kevin_mcq
Message 5 of 8
The connection was the same low speed prior to the reset - and had been up for several days prior.
imjolly
Message 6 of 8
are you current still in test socket with a new filter?  do you use a phone extension cable to reach the test socket?
I think all the attempts to improve your connection and/or router dropping connection have left you in banded profile.  this should release automatically give 3+ days stable connection with no resets.  if you get 3+ days and no change then repost the last 2 line of adslstats from hub and mods will help get you out banding  http://www.plus.net/support/broadband/speed_guide/broadband_terminology.shtml
kevin_mcq
Message 7 of 8
That may well be the case - the bandwidth is showing as 440/284 and the latency is interleaved (as a possible error correction).
I'm still in the test socket (no extension used to reach) and have added a new filter (I suspect the reset at 12 happened due to moving sockets).
I'll leave for 3-4 days and see if any improvement. For ADSL stats, simply the upload/ download from the hub manager?
Thanks again...
imjolly
Message 8 of 8
as you have a HH4 the stats will be the 2 lines you previously posted as there are no adsl stats like previous hubs  if there are no drops/resets then it should be the same 2 lines as previously
