Keith_Beddoe
Message 11 of 23
Re: Panasonic Smart TV connection HH4
Have you tried a direct connection or broadband extenders?
icclebug
Message 12 of 23
No not yet, although wireless is working fine when it's not connected to BT. The engineers tested it lots of times before leaving and never dropped connection once.
Keith_Beddoe
Message 13 of 23
Its just the poor performance of BT Home hubs wireless, I use separate wireless access points with my home hub 1, as that one (the very first home hub) suffers from the same issues. Its not a signal level issue as the HH1 has an external aerial, its just that if you try to stream continuous data over wireless, it simply gives up and disconnects.
I don`t think any of the later home hubs are any better in that respect.
icclebug
Message 14 of 23
Back to the TP Link router you suggested previously?
Keith_Beddoe
Message 15 of 23
Did you buy one. I cannot remember?
If you did, then there is no harm in trying it.
icclebug
Message 16 of 23
My wife took it back as everything was working fine...against my advice 🙂
Do you think the router is the problem? If that's the case it's worth trying another. I do also have another HH4 but maybe it will be the same issue.
Can easily get another though. It is really strange given this happened straight after turning off parental controls.
I'm presuming no point contacting BT?
Keith_Beddoe
Message 17 of 23
Is it practical to run a temporary Ethernet cable from the home hub to the TV?
If not, then Broadband extenders are going to be the next best solution.
https://www.shop.bt.com/products/bt-broadband-extender-600-kit-084284-BVFL.html
These are specifically designed for that purpose. You can get them from Amazoon as well as the BT Shop.
That would be a better option than changing the router at this stage.
icclebug
Message 18 of 23
I can although really not ideal.
There are lots of these extenders in Argos, TP Link versions, any good?
Keith_Beddoe
Message 19 of 23
I used to use a couple of TP Link ones, but they had a habit of going into standby and not waking up again. That was a few years ago, so there may have been a firmware upgrade.
I  now use some old Comtrend ones, and they are fine.
You could always try a couple, and see if they work, at least they are easy to return if you have problems.
I see Argos do the BT ones. 498/9512
icclebug
Message 20 of 23
Fai enough, worth a try. Cheers Keith.
