Just installed BTHub6 plugged into Mastersocket 5c Mk 4 and no problem connecting my Apple Mac laptop. Broadband speed above 40Mps.The Hub is in one room separated from my Laptop by the room wall ; no problem. My TV is in the same room as the laptop ; Why can't it connect to the Hub in the same way as the laptop? It suggests YVM102
Secondly, the Menu on my Panasonic TV allows me to choose "wireless", but when I open Youview ; Network and Internet ; Settings ; it reads Wired Connection and there is no option to choose "wireless connection" in Youview settings. Is that a problem?
If the solution is to purchase those mini hubs or Connectors what specifically should I be buying? There appears to be a choice.
