Message 11 of 19
Re: Panasonic Vieirara and BT Home Hub
Hi, yes I have just tried the fixes within http://bt.custhelp.com/app/answers/detail/a_id/44798/~/i-have-problems-connecting-5ghz-and-dual-band...
however my tv is still not connecting.  Dors anyone have any other ideas?
Message 12 of 19
Message 13 of 19
Thanks, am adding the manual IP settings in now.  What should I use for Proxy and Proxy port?
Message 14 of 19
Leave them blank, as you are not using a proxy server.
Message 15 of 19
Thank you, i'll see if this now works
Message 16 of 19
Please could you update this thread with the result. Thanks.
Message 17 of 19
Still no luck I'm afraid. Haven't had a chance to explore further yet, any ideas?
Message 18 of 19
Did you also disable 'Smart setup', that link doesn't mention it.
Message 19 of 19
No really, perhaps a search on the Panasonice fourums, if they exist, may help.
Other people on this forum have got theirs working, so maybe you need someone local to you, with networking experience.
Quite often, the solution is something very simple, like BT Parental controls active.
Using an Ethernet cable from the home hub to the TV, can eliminate any issues with a wireless connection.
