TheRealBudski
Message 1 of 14
Parental Control
Hi All
I've been trying to setup the parental control for the last couple of months without success. When I first started I pressed the Activate button, and got a screen telling me it was being setup, and to check back in 24 hours.
Ever since then, the Parental Controls have shown as unavailable.
I've spent countless conversations withh the Indian call center and I'm not sure they really get what the issue is. In addition, they dont seem willing/able to pass me through to someone who can help because they are apparently an 'off line' team.
I could rant on about how they either dont call back when they say they will or calling the wrong number, but it wont help here.
Can one of the Mod's please see if they can assist here and finally get the controls turned on, otherwise I'm going to have to start looking at creating a DHCP server and passing my DNS via OpenDNS.
thanks in advance
13 REPLIES 13
RobbieMac
Moderator
Moderator
Message 2 of 14
Re: Parental Control
Hi @TheRealBudski
Welcome to the community and thanks for your post!
Sorry for the problems you're having activating Parental Controls.  The community isn't going to be able to help with this so you can send us over your details and we'll give you a hand to activate the service from here.
Click on my username here >> RobbieMac << and you'll see our contact link on the left hand side underneath my profile picture.
Cheers,
Robbie
TheRealBudski
Message 3 of 14
Hi
thanks for the speedy reply, I've answered as requested
Cheers
PaddyB
Moderator
Moderator
Message 4 of 14
Hi @TheRealBudski,
Thank you for sending in your details. I'm sorry you're experiencing issues with the BT Parental Controls. I've raised this with the Parental Controls team and they're currently investigating the issue. I should have an update for you in the next 48 hour and I'll be in touch as soon as I know more.
PaddyB
TheRealBudski
Message 5 of 14
Thanks very much.
I did check this morning, and it was still not available, but the fault is no longer showing in the faults screen
cheers
PaddyB
Moderator
Moderator
Message 6 of 14
Hi @TheRealBudski,
I gave your mobile number a quick call, I'm sorry I didn't get speaking to you today. The BT Parental Controls are now showing as active on your account. Please can you check if the service is working at your end?
PaddyB
TheRealBudski
Message 7 of 14
Hi
no idea why it didn’t ring,anyway it is showing as active on the screen, but when I try and modify the settings I get the following
Sorry, something went wrong. Please try again in 15 minutes.
Ive tried with IE11 and on an iPad with the same results
thanks
PaddyB
Moderator
Moderator
Message 8 of 14
Hi @TheRealBudski,
Thank you for getting back to me. I'm sorry that hasn't worked. I've sent this off for further investigation and I should have an update for you tomorrow.
PaddyB
TheRealBudski
Message 9 of 14
Hi guys
i haven’t heard anything back since.
Are there any internal updates to the support ticket?
StuartH
Moderator
Moderator
Message 10 of 14
Hi @TheRealBudski
I can see @PaddyB is looking after this one for you.
He's in the office this afternoon and will be in touch with an update.
Stuart
